Datasheet Texas Instruments TPS6755IP — Даташит
СерияTPS6755
МодельTPS6755IP
Регулируемый инвертирующий преобразователь постоянного тока в постоянный ток 8-PDIP
Adjustable Inverting DC/DC Converter datasheet
PDF, 434 Кб, Версия: A, Файл опубликован: 1 дек 1996
16 предложений от 15 поставщиков
IC REG BCK BST ADJ 270MA 8DIP. Buck-Boost Switching Regulator IC Negative Adjustable -1.22V 1 Output 270mA 8-DIP (0.300', 7.62mm). PMIC...
Рутоника
TPS6755IP
234 ₽
TPS6755IP
367 ₽
Элитан
TPS6755IP
878 ₽
TPS6755IP
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
  • TPS6755 Evaluation Using the TSP6735EVM
    PDF, 36 Кб, Файл опубликован: 23 май 2003
    This application note describes how the TPS6755 can be evaluated using the TPS6735EVM.
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TPS6755 (5)
  • Semiconductors > Power Management > DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS6755IP
