Datasheet Texas Instruments LM339PWLE — Даташит
СерияLM339
МодельLM339PWLE
Четверной дифференциальный компаратор 14-TSSOP от 0 до 70
LMx39x, LM2901xx Quad Differential Comparators datasheet
PDF, 1.4 Мб, Версия: T, Файл опубликован: 30 июн 2015
Pin14
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)0.07 | 1ku
Input Bias Current (+/-)(Max)(nA)50
Iq per channel(Max)(mA)0.5
Number of Channels(#)4
Тип выходаOpen Collector
Package GroupTSSOP
Rail-to-RailOut
Special FeaturesN/A
VICR(Max)(V)3.5
Vos (Offset Voltage @ 25C)(Max)(mV)5
Vs(Max)(V)30
Vs(Min)(V)2
tRESP Low - to - High(us)0.3
RoHSНе совместим
  • A Quad of Independently Func Comparators (Rev. A)
    PDF, 1.6 Мб, Версия: A, Файл опубликован: 23 апр 2013
    This application note discusses the features, design, and uses of the LM139/LM239/LM339 family ofdevices.
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM339PWLE
