Datasheet Texas Instruments MSP430F67641IPZR — Даташит
СерияMSP430F67641
МодельMSP430F67641IPZR
MSP430F676x1 — недорогой трехфазный измерительный преобразователь SOC 100-LQFP от -40 до 85
MSP430F676x1 Polyphase Metering SoCs datasheet
PDF, 1.7 Мб, Файл опубликован: 2 июн 2014
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаF67641
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCADC10 - 6ch,SigmaDelta24 - 3ch
AESN/A
Active Power346.8 uA/MHz
Additional FeaturesLCD,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
DMA3
Featuredf6
Тактовая частота25 МГц
GPIO Pins72
I2C1
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory128 KB
Package GroupLQFP
Package Size: mm2:W x L80LQFP: 196 mm2: 14 x 14(LQFP) PKG
RAM8 KB
SPI4
Special I/ON/A
Standby Power2.9 LPM3-uA
Timers - 16-bit4
UART3
Wakeup Time3 us
  • Evaluation Modules & Boards: EVM430-F67641
    Polyphase Electric Meter with MSP430F67641 SoC
  • Evaluation Modules & Boards: EVM430-F6779
    EVM430-F6779 - 3 Phase Electronic Watt-Hour EVM for Metering
    MSP EnergyTrace Technology
  • Implementation of a Low-Cost Three-Phase Watt-Hour Meter Using the MSP430F67641 (Rev. C)
    PDF, 2.9 Мб, Версия: C, Файл опубликован: 5 авг 2015
    This application report describes the implementation of a low-cost three-phase electronic electricity meter using the Texas Instruments MSP430F67641 metering processor. This application report includes the necessary information with regard to metrology software and hardware procedures for this single-chip implementation.
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
На английском языке: Datasheet Texas Instruments MSP430F67641IPZR
