Datasheet Texas Instruments TLV2217-33KTPR — Даташит
СерияTLV2217
МодельTLV2217-33KTPR
TLV2217 Low-Dropout Fixed-Voltage Regulators datasheet
PDF, 1.2 Мб, Версия: M, Файл опубликован: 18 ноя 2016
IC REG LIN 3.3V 500MA 2POWERFLEX. Linear Voltage Regulator IC 1 Output 500mA 2-PowerFLEXTM. PMIC - Voltage Regulators - Linear...
TLV2217-33KTPR
65 ₽
727GS
TLV2217-33KTPR
от 872 ₽
Рутоника
TLV2217-33KTPR
TLV2217-33KTPR
Pin2
Package TypeKTP
Industry STD TermPFM
JEDEC CodeR-PSFM-G
Маркировка2217-33
Width (мм)6.15
Length (мм)6.04
Thickness (мм)1.91
Pitch (мм)4.57
Max Height (мм)2.03
Accuracy(%)2
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.33 | 1ku
Fixed Output Options(V)1.8
2.5
3.3
Iout(Max)(A)0.5
Iq(Typ)(mA)2
Operating Temperature Range(C)0 to 125
Output OptionsFixed Output
Package GroupTO-220
TO-252
TSSOP
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
See datasheet (CDIP)
See datasheet (PFM)
Regulated Outputs(#)1
Vdo(Typ)(mV)500
Vin(Max)(V)12
Vin(Min)(V)3
Vout(Max)(V)3.3
Vout(Min)(V)1.8
RoHSНе совместим
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
TLV221733KTPR, TLV2217 33KTPR
На английском языке: Datasheet Texas Instruments TLV2217-33KTPR
