Datasheet Texas Instruments TL034MN — Даташит
Серия | TL034 |
Модель | TL034MN |
Прецизионный операционный усилитель с четырьмя усовершенствованными JFET маломощными 14-PDIP от -55 до 125
Enhanced-JFET Low-Power Low-Offset Operational Amplifiers datasheet
PDF, 1.8 Мб, Версия: C, Файл опубликован: 3 дек 2001
Pin | 14 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Additional Features | N/A |
Approx. Price (US$) | 0.59 | 1ku |
Архитектура | FET |
CMRR(Min)(dB) | 75 |
CMRR(Typ)(dB) | 94 |
GBW(Typ)(MHz) | 1.1 |
Input Bias Current(Max)(pA) | 200 |
Iq per channel(Max)(mA) | 0.28 |
Iq per channel(Typ)(mA) | 0.217 |
Number of Channels(#) | 4 |
Offset Drift(Typ)(uV/C) | 10.9 |
Operating Temperature Range(C) | -40 to 85 0 to 70 |
Output Current(Typ)(mA) | 8 |
Package Group | PDIP |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rail-to-Rail | In to V+ |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 2.9 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 30 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 10 |
Vn at 1kHz(Typ)(nV/rtHz) | 41 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 4 |
RoHS | Не совместим |
- Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
Серия: TL034 (18)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
