Datasheet Texas Instruments TPS65263QRHBRQ1 — Даташит
СерияTPS65263-Q1
МодельTPS65263QRHBRQ1
Тройной синхронный понижающий преобразователь, Vin, 4,0–18 В, 3A/2A/2A с динамическим масштабированием напряжения, управляемым I2C, 32-VQFN от -40 до 125
TPS65263-Q1 4.0- to 18-V Input Voltage, 3-A/2-A/2-A Output Current Triple Synchronous Step-Down Converter With I2C Controlled Dynamic Voltage Scaling datasheet
PDF, 1.8 Мб, Версия: C, Файл опубликован: 19 ноя 2015
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)5
Length (мм)5
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
Control ModeCurrent Mode
Duty Cycle(Max)100 %
Основные особенностиDynamic Voltage Scaling,Enable,Frequency Synchronization,Light Load Efficiency,Phase Interleaving,Power Good,Synchronous Rectification,UVLO Adjustable
Iout(Max)3 A
Iq(Typ)0.6 мА
Package GroupVQFN
RatingAutomotive
Regulated Outputs3
Switching Frequency(Max)2300 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)18 В
Vin(Min)4 В
Vout(Max)16 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS65263EVM-645
    TPS65263EVM Evaluation Module
  • Low Conducted EMI Power Solution for Automotive Digital Cockpit With LMR14050 an
    PDF, 1.9 Мб, Файл опубликован: 7 фев 2018
    For automotive electronics a challenge is electromagnetic interference (EMI). The circuit schematic andprinted circuit board (PCB) are critical to achieving excellent EMI performance for the power rail in theautomotive digital cockpit. Therefore knowing how to choose the IC and design the circuit has the mostsignificant impact while knowing how to optimize the board layout is also pivotal
Серия: TPS65263-Q1 (2)
  • Semiconductors > Power Management > DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS65263QRHBRQ1
