Datasheet ТI LM5161QPWPQ1 — Даташит
| Серия | LM5161-Q1 |
| Модель | LM5161QPWPQ1 |
Синхронный понижающий/понижающий преобразователь с широким входом, 4,5–100 В, 1 А, 14-HTSSOP
LM5161-Q1 Wide Input 100-V, 1-A Synchronous Buck/Fly-Buckв„ў Converter datasheet
PDF, 2.1 Мб, Файл опубликован: 23 авг 2016
- Is Your IGBT Gate-Driver Power Supply OptimizedPDF, 115 Кб, Файл опубликован: 12 мар 2015
Insulated Gate Bipolar Transistors (IGBTs) are used in high current three-phase AC motors. This application report discusses the theory and requirements of gate-drive power supply for IGBTs. It also discusses the isolation requirements and calculation of correct amount of IGBT drive power. - AN-2292 Designing an Isolated Buck (Fly-Buck) Converter (Rev. C)PDF, 870 Кб, Версия: C, Файл опубликован: 17 дек 2014
In many applications, one or more low-cost, simple to use, isolated power supplies working from input voltages up to 100 V are needed. Traditional solutions use flyback converters to generate this bias supply. Flyback designs typically utilize asymmetric transformers turns ratios for primary and secondary power windings, with an optocoupler and reference, or an auxiliary winding for feedback regul - Fly-Buck(TM) converter provides EMC and isolation in PLC applicationsPDF, 201 Кб, Файл опубликован: 29 янв 2015
Серия: LM5161-Q1 (3)
- LM5161QPWPQ1 LM5161QPWPRQ1 LM5161QPWPTQ1
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
