Datasheet Texas Instruments SN74LVC157D — Даташит
СерияSN74LVC157
МодельSN74LVC157D
Четверной 2-строчный селектор данных/мультиплексор 16-SOIC от -40 до 85
Datasheet
TSP
Quadruple 2-Line To 1-Line Data Selector/Multiplexer 16-SOIC -40 to 85
TradeElectronics
SN74LVC157D
SN74LVC157D
SN74LVC157D
727GS
SN74LVC157D
Pin16
Package TypeD
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC157 (4)
  • Semiconductors > Logic > Specialty Logic > Decoder/Encoder/Multiplexer
На английском языке: Datasheet Texas Instruments SN74LVC157D
