Datasheet Texas Instruments SN74CBTS3306PW — Даташит
СерияSN74CBTS3306
МодельSN74CBTS3306PW
Переключатель шины на двух полевых транзисторах с ограничением на диоде Шоттки 8-TSSOP от -40 до 85
SN74CBTS3306 datasheet
PDF, 1.0 Мб, Версия: I, Файл опубликован: 15 янв 2004
Package TypePW
Industry STD TermTSSOP
Package QTY150
МаркировкаCR306
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
На английском языке: Datasheet Texas Instruments SN74CBTS3306PW
