Datasheet Texas Instruments SN74AHCT14QPWRQ1 — Даташит
СерияSN74AHCT14Q-Q1
МодельSN74AHCT14QPWRQ1
Автомобильный каталог Инверторы с шестигранным триггером Шмитта 14-TSSOP от -40 до 125
Hex Schmitt-Trigger Inverters datasheet
PDF, 796 Кб, Версия: A, Файл опубликован: 29 апр 2008
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаHB14Q
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits6
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-8/8 мА
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
RatingAutomotive
Schmitt TriggerYes
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9 нс
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AHCT14QPWRQ1
