Datasheet Texas Instruments LM2931T-5.0 — Даташит
СерияLM2931-N
МодельLM2931T-5.0
Регуляторы серии с низким падением напряжения 3-TO-220 от -40 до 85
LM2931 Series Low Dropout Regulators datasheet
PDF, 3.4 Мб, Версия: G, Файл опубликован: 3 апр 2013
Pin33
Package TypeNDENDE
Industry STD TermTO-220TO-220
JEDEC CodeR-MSFM-PR-MSFM-P
МаркировкаLM2931T5.0
Width (мм)10.1610.16
Length (мм)14.98614.986
Thickness (мм)4.5724.572
Pitch (мм)2.542.54
Max Height (мм)4.74.7
Рекомендуемая замена
ReplacementLM2931T-5.0/NOPB
Replacement CodeS
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.25 | 1ku
Fixed Output Options(V)5
Iout(Max)(A)0.1
Iq(Typ)(mA)0.4
Operating Temperature Range(C)-40 to 85
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)53
Package GroupTO-220
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
Regulated Outputs(#)1
Vdo(Typ)(mV)300
Vin(Max)(V)26
Vin(Min)(V)4
Vout(Max)(V)24
Vout(Min)(V)3
RoHSНе совместим
  • TO-92 Packing Options / Ordering Instructions (Rev. A)
    PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
  • AB-12 Wide Adjustable Range PNP Voltage Regulator (Rev. B)
    PDF, 47 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the PNP voltage regulator.
  • High-Efficiency Reg has Low Drop-Out Voltage (Rev. B)
    PDF, 60 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Conventional regulators have a high drop-out voltage that is a function of the total output current.However with just a regulator chip an external transistor and a few passive components this designforms a high output current regulator with a limited input voltage and high efficiency. The circuit presentedhas a drop-out of 0.7V at 5A load current and 1.3V at a current level of as high as
LM2931T5.0, LM2931T 5.0
На английском языке: Datasheet Texas Instruments LM2931T-5.0
