Datasheet Texas Instruments CD54HCT280F3A — Даташит
Серия | CD54HCT280 |
Модель | CD54HCT280F3A |
Высокоскоростная КМОП-логика, 9-битный генератор четности/четности/проверка 14-CDIP от -55 до 125
CD54HC280, CD74HC280, CD54HCT280, CD74HCT280 datasheet
PDF, 708 Кб, Версия: D, Файл опубликован: 21 окт 2003
Купить CD54HCT280F3A на РадиоЛоцман.Цены — от 140 до 3 708 ₽ 11 предложений от 11 поставщиков Микросхема Счётчик, Parity Generator/Checker 9Bit 14Pin CDIP Tube | |||
CD54HCT280F3A Texas Instruments | 2 242 ₽ | ||
CD54HCT280F3A Texas Instruments | 2 868 ₽ | ||
CD54HCT280F/3A Texas Instruments | по запросу | ||
CD54HCT280F3A | по запросу |
Pin | 14 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | CD54HCT280F3A |
Width (мм) | 6.67 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Bits | 2 |
F @ Nom Voltage(Max) | 25 Mhz |
Function | Counter |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 4/-4 мА |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | HCT |
Тип | Other |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 56 нс |
RoHS | See ti.com |
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT280 (1)
- CD54HCT280F3A
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
