Клеммники KEEN SIDE
Datasheet Texas Instruments TPS7301QPWLE — Даташит
СерияTPS73
МодельTPS7301QPWLE
Стабилизаторы напряжения 500 мА с малым падением напряжения и встроенной функцией сброса задержки 20-TSSOP от -40 до 125
Low-Dropout Voltage Regulators With Integrated Delayed Reset Function datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 8 мар 1999
TPS7301QPWLE
Pin20
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementTPS7301QPWR
Replacement CodeS
Accuracy(%)2
Additional FeaturesEnable
Overcurrent Protection
Power Good
Thermal Shutdown
Approx. Price (US$)1.16 | 1ku
Fixed Output Options(V)2.5
3
3.3
4.8
5
Iout(Max)(A)0.5
Iq(Typ)(mA)0.34
Noise(uVrms)74
Operating Temperature Range(C)-40 to 125
-40 to 85
Output OptionsAdjustable Output
Fixed Output
Package GroupTSSOP
Regulated Outputs(#)1
Vdo(Typ)(mV)270
Vin(Max)(V)10
Vin(Min)(V)2.47
Vout(Max)(V)9.75
Vout(Min)(V)1.2
RoHSНе совместим
  • Voltage Regulator Solutions for Xilinx Virtex E Dual Voltage FPGAs
    PDF, 77 Кб, Файл опубликован: 13 июн 2000
    This application report serves as a reference for engineers designing with Xilinix 2.5-V and 1.8-V Virtex multivoltage FPGA products. It provides basic information on the issues facing engineers not experienced with multivoltage type products.
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TPS7301QPWLE
