Datasheet Texas Instruments TXS0104EDG4 — Даташит
СерияTXS0104E
МодельTXS0104EDG4
4-битный двунаправленный преобразователь уровня напряжения для приложений с открытым стоком и двухтактной схемы 14-SOIC от -40 до 85
TXS0104E 4-Bit Bidirectional Voltage-Level Translator for Open-Drain and Push-Pull Applications datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 29 сен 2017
Pin14
Package TypeD
Package QTY50
МаркировкаTXS0104E
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits4
F @ Nom Voltage(Max)12 Mhz
ICC @ Nom Voltage(Max)0.0144 мА
Max Drive24 мА
Schmitt TriggerNo
Technology FamilyTXS
VCCA(Max)3.6 В
VCCA(Min)1.65 В
VCCB(Max)5.5 В
VCCB(Min)2.3 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)9.6,10 нс
  • Evaluation Modules & Boards: BOOST-CC2564MODA
    Dual-mode BluetoothВ® CC2564 module with integrated antenna BoosterPackВ™ plug-in module
  • Effects of pullup and pulldown resistors on TXS and TXB devices
    PDF, 732 Кб, Файл опубликован: 20 сен 2017
    The TXS and TXB family of devices belong to the auto-bidirectional translation products from TI. These devices can be sensitive to external pullup or pulldown resistors due to the internal pullup resistors present in the TXS device and the internal serial resistors present in the TXB device. In this application note, the effects of external pullup and pulldown resistors on VOL and VOH levels of th
  • A Guide to Voltage Translation With TXS-Type Translators
    PDF, 287 Кб, Файл опубликован: 29 июн 2010
    Modern trends are driving the need for lower supply voltages across many system-level designs. As most processor voltage levels continue to decrease in the interest of achieving the lowest possible power consumption, peripheral devices maintain a need for higher voltage levels, creating potential for voltage discontinuities within a system. To remedy this mixed voltage system incompatibility, a vo
  • Semiconductors > Logic > Voltage Level Translation > Bidirectional Voltage Translation
На английском языке: Datasheet Texas Instruments TXS0104EDG4
