Datasheet Texas Instruments SN74HC166PWRE4 — Даташит
СерияSN74HC166
МодельSN74HC166PWRE4
8-битные регистры сдвига с параллельной загрузкой 16-TSSOP от -40 до 85
SN54HC166, SN74HC166 datasheet
PDF, 1.8 Мб, Версия: D, Файл опубликован: 15 сен 2003
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаHC166
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
3-State OutputNo
Approx. Price (US$)0.12 | 1ku
F @ Nom Voltage(Max)(Mhz)28
ICC @ Nom Voltage(Max)(mA)0.08
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)5.2/-5.2
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)(V)6
VCC(Min)(V)2
Voltage(Nom)(V)6
tpd @ Nom Voltage(Max)(ns)32
  • HCMOS Design Considerations (Rev. A)
    PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
    This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
  • Semiconductors > Logic > Flip-Flop/Latch/Register > Shift Register
На английском языке: Datasheet Texas Instruments SN74HC166PWRE4
