Datasheet Texas Instruments THS4304DRG4 — Даташит
СерияTHS4304
МодельTHS4304DRG4
Широкополосный операционный усилитель 8-SOIC от -40 до 85
THS4304: Wideband Operational Amplifier datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 30 июл 2004
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic(dBc)84
3rd Harmonic(dBc)100
@ MHz10
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)2.41 | 1ku
АрхитектураBipolar
Voltage FB
BW @ Acl(MHz)3000
CMRR(Min)(dB)80
CMRR(Typ)(dB)95
GBW(Typ)(MHz)3000
Input Bias Current(Max)(pA)12000000
Iq per channel(Max)(mA)18.9
Iq per channel(Typ)(mA)18
Number of Channels(#)1
Offset Drift(Typ)(uV/C)5
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)100
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)790
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vn at Flatband(Typ)(nV/rtHz)2.4
Vos (Offset Voltage @ 25C)(Max)(mV)4
RoHSНе совместим
  • Evaluation Modules & Boards: THS4304DGKEVM
    THS4304 Evaluation Module for DGK Package
  • Evaluation Modules & Boards: THS4304DBVEVM
    THS4304 Evaluation Module for DBV Package
  • RF and IF amplifiers with op amps
    PDF, 177 Кб, Файл опубликован: 28 фев 2005
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS4304DRG4
