Datasheet Texas Instruments THS4031IDG4 — Даташит
СерияTHS4031
МодельTHS4031IDG4
Малошумящий усилитель с обратной связью по напряжению, 100 МГц, 8-SOIC от -40 до 85
THS403x 100-MHz Low-Noise High-Speed Amplifiers datasheet
PDF, 1.6 Мб, Версия: H, Файл опубликован: 30 июн 2016
Package TypeD
Package QTY75
Маркировка4031I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic81 dBc
3rd Harmonic81 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl200 МГц
CMRR(Min)85 дБ
CMRR(Typ)95 дБ
GBW(Typ)200 МГц
Input Bias Current(Max)6000000 pA
Iq per channel(Max)10 мА
Iq per channel(Typ)8.5 мА
Количество каналов1
Offset Drift(Typ)2 uV/C
Output Current(Typ)90 мА
Rail-to-RailNo
Slew Rate(Typ)100 V/us
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.6 нВ/rtГц
Vn at Flatband(Typ)1.6 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Evaluation Modules & Boards: THS4031EVM
    THS4031 High Speed Amplifier Evaluation Module
  • Accurately measuring ADC driving-circuit settling time (Rev. A)
    PDF, 107 Кб, Версия: A, Файл опубликован: 18 май 2015
  • Low Power Input and Reference Driver Circuit for ADS8318 and ADS8319
    PDF, 1.5 Мб, Файл опубликован: 24 июн 2009
    The one size fits all approach to operational amplifiers is not effective. Every application has its own specific requirements that must be fulfilled. Appropriate selection of the op amp that drives an analog-to-digital converter (ADC) in a low-power application is a critical step. Most available low-power op amps trade off low-power features with other parameters such as bandwidth, settling t
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS4031IDG4
