Datasheet Texas Instruments OPA1688ID — Даташит
СерияOPA1688
МодельOPA1688ID
Операционные усилители звука Rail-to-Rail с низким уровнем искажений, 36 В, 10 МГц, с высоким уровнем передачи сигнала, 8-SOIC, от -40 до 85
OPA168x SoundPlus 36-V, Single-Supply, 10-MHz, Rail-to-Rail Output Operational Amplifiers datasheet
PDF, 3.0 Мб, Файл опубликован: 9 сен 2015
Package TypeD
Package QTY75
МаркировкаO1688A
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesBurr-Brownв„ў Audio,EMI Hardened,High Cload Drive,Tiny Package
АрхитектураCMOS
CMRR(Min)104 дБ
CMRR(Typ)120 дБ
GBW(Typ)10 МГц
Input Bias Current(Max)20 pA
Iq per channel(Max)1.8 мА
Iq per channel(Typ)1.6 мА
Количество каналов2
Offset Drift(Typ)0.5 uV/C
Output Current(Typ)75 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)8 V/us
Total Supply Voltage(Min)4.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)1.5 мВ
  • Evaluation Modules & Boards: OPA1688EVM
    OPA1688 SoundPlus Audio Operational Amplifier Evaluation Module
  • HiFi Audio Circuit Design
    PDF, 252 Кб, Файл опубликован: 23 авг 2017
    With the increase in personal electronic devices, HiFi audio is more popular than ever in many applications, such as smartphones, music players, home theaters, and even car infotainment. Many engineers and consumers devote themselves to the endless journey in HiFi audio. This document will help engineers understand, judge, design, and optimize a HiFi audio circuit.
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA1688 (4)
На английском языке: Datasheet Texas Instruments OPA1688ID
