Datasheet Texas Instruments INA114AU/1KE4 — Даташит
| Серия | INA114 |
| Модель | INA114AU/1KE4 |
Прецизионный инструментальный усилитель 16-SOIC от -40 до 85
Precision Instrumentation Amplifier datasheet
PDF, 749 Кб, Файл опубликован: 27 сен 2000
Купить INA114AU/1KE4 на РадиоЛоцман.Цены — от 150 до 749 ₽10 предложений от 10 поставщиков Микросхема Усилитель прибора, Precision Instrumentation Amplifier 16-SOIC -40℃ to 85℃ | |||
| INA114AU/1KE4 Texas Instruments | 338 ₽ | ||
| INA114AU/1KE4 Texas Instruments | 749 ₽ | ||
| INA114AU/1KE4 Texas Instruments | по запросу | ||
| INA114AU/1KE4 | по запросу | ||
| Pin | 16 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | INA114AU |
| Width (мм) | 7.5 |
| Length (мм) | 10.3 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Bandwidth at Min Gain(Typ) | 1 МГц |
| CMRR(Min) | 110 дБ |
| Gain Error (+/-)(Max) | 2 % |
| Gain Non-Linearity (+/-)(Max) | 0.002 % |
| Gain(Max) | 10000 V/V |
| Gain(Min) | 1 V/V |
| Input Bias Current (+/-)(Max) | 2 нА |
| Input Offset (+/-)(Max) | 50 uV |
| Input Offset Drift (+/-)(Max) | 0.25 uV/C |
| Iq(Typ) | 2.2 мА |
| Noise at 0.1 Hz - 10 Hz(Typ) | 0.4 uVpp |
| Noise at 1kHz(Typ)(nV/rt | 11 Hz |
| Количество каналов | 1 |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
| Rating | Catalog |
| Vs(Max) | 36 В |
| Vs(Min) | 4.5 В |
- Use Low-Impedance Bridges on 4-20mA Current LoopPDF, 27 Кб, Файл опубликован: 27 сен 2000
If you need more transducer excitation current than is available on a standard 4-20mA 2-wire current loop, consider a 3-wire transmitter. A 2-wire 4-20mA transmitter uses the same two wires for signal and power. Part of the 4mA minimum loop current is used to power the transmitter circuitry. The remaining current can be used for transducer excitation. In some applications even the entire 4mA is no
Серия: INA114 (12)
- Semiconductors > Amplifiers > Instrumentation Amplifiers
