Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI LM2940-5.0-MW8 — Даташит
СерияLM2940QML
МодельLM2940-5.0-MW8
Datasheet Texas Instruments LM2940-5.0-MW8
Линейный регулятор выхода военного класса 1А, 5В / LDO 0-WAFERSALE от -55 до 125
LM2940QML 1A Low Dropout Regulator datasheet
PDF, 384 Кб, Версия: B, Файл опубликован: 2 май 2013
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: LM2940QML (3)
  • Semiconductors > Space & High Reliability > Power Management Products > Linear Regulators (LDO)
LM29405.0MW8, LM2940 5.0 MW8
На английском языке: Datasheet Texas Instruments LM2940-5.0-MW8
Политика конфиденциальности
