Datasheet Texas Instruments SNJ54AS1004AFK — Даташит
СерияSN54AS1004A
МодельSNJ54AS1004AFK
Шестнадцатеричные инвертирующие драйверы 20-LCCC от -55 до 125
Hex Inverting Drivers datasheet
PDF, 913 Кб, Версия: B, Файл опубликован: 1 янв 1995
Микросхема Логический чип, Driver 6CH Inverting Bipolar 20Pin CLLCC Tube
SNJ54AS1004AFK
1 388 ₽
SNJ54AS1004AFK
6 562 790 ₽
ТаймЧипс
SNJ54AS1004AFK
SNJ54AS1004AFK
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка88729012ASNJ54AS1004AFK5962-
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
Bits6
Тип входаTTL
Тип выходаTTL
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
На английском языке: Datasheet Texas Instruments SNJ54AS1004AFK
