Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS1211UG4 — Даташит
СерияADS1211
МодельADS1211UG4
24-битный аналого-цифровой преобразователь 24-SOIC от -40 до 85
24-Bit Analog-to-Digital Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 8 сен 2005
Pin24
Package TypeDW
Package QTY25
МаркировкаADS1211U
Width (мм)7.5
Length (мм)15.4
Thickness (мм)2.35
Max Height (мм)2.65
  • How to get 23 bits of effective resolution from your 24-bit converter
    PDF, 96 Кб, Файл опубликован: 27 сен 2000
    The ADS1210 and ADS1211 are precision, wide dynamic range, delta-sigma A/D converters that have 24 bits of no missing code and up to 23 bits rms of effective resolution. Because of the nature of the delta-sigma design architecture the circuit designer has control over more of the variables and interface options in the A/D's conversion process than is realizable with other converter architectures.
  • Calibration Routines and Register Value Generation for the ADS121x Series
    PDF, 298 Кб, Файл опубликован: 19 июн 2003
    In order to achieve the best possible performance, offset and gain can be often be calibrated in high-resolution analog-to-digital converters (ADCs). Changes in temperature, PGA gain, power supply voltage, or most importantly, decimation ratio can influence the accuracy of measurement. This application note explains how the calibration routines work and how to generate values for the full-scale re
  • Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma Converters
    PDF, 105 Кб, Файл опубликован: 27 сен 2000
    Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems.
  • Inputs Currents for High-Resolution ADCs
    PDF, 127 Кб, Файл опубликован: 6 мар 2003
  • AB-174: Getting the Full Potential from your ADC (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
    Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
На английском языке: Datasheet Texas Instruments ADS1211UG4
