Datasheet Texas Instruments MSP430P112AY — Даташит
СерияMSP430P112
МодельMSP430P112AY
16-битный микроконтроллер со сверхнизким энергопотреблением, 4 КБ OTP, 256 байт ОЗУ 0-DIESALE от -40 до 85
Package TypeY
RoHSНе совместим
  • Evaluation Modules & Boards: MSP-PRGS430
    MSP430 OTP & UV-EPROM Serial Programmer
    Статус продукта: NRND (Не рекомендуется для новых разработок)
    MSP EnergyTrace Technology
  • Low Cost TRIAC Control with MSP430 16-Bit Microcontroller (Rev. A)
    PDF, 328 Кб, Версия: A, Файл опубликован: 1 июн 1999
    This application report describes a complete triac control system using the MSP430. An example of a triac control system is presented and analyzed. Methods for interference reduction, modification for high speed, and enhance security are explained. Alternate power supply circuits are included. A listing of triac control software available is presented in Appendixes A1 through A3.
  • MSP430 Embedded Application Binary Interface
    PDF, 596 Кб, Файл опубликован: 16 май 2012
    This document is a specification for the ELF-based Embedded Application Binary Interface (EABI) for the MSP430 family of processors from Texas Instruments. The EABI defines the low-level interface between programs, program components, and the execution environment, including the operating system if one is present. Components of the EABI include calling conventions, data layout and addressing conve
  • MSP430 Isolated FET Interface
    PDF, 1.2 Мб, Файл опубликован: 10 окт 2003
    This application report describes how to build an isolated FET interface for the MSP430 Flash Emulation Tool (FET). When developing and debugging line-powered MSP430applications such as motor control, electricity energy meters, power monitoring systems etc. it is important to have electrical isolation for the development tool such that the personnel involved and the connected electronic equipmen
  • HDQ Protocol Implementation with MSP430
    PDF, 124 Кб, Файл опубликован: 19 фев 2004
  • Spread-Spectrum Clock Source Using an MSP430
    PDF, 228 Кб, Файл опубликован: 31 май 2006
    While spread-spectrum clocking has long since been used in processor and memory clock trees, there are many other clocked systems, such as power supplies or switch-mode amplifiers, that continue to use a single-frequency clock. This can, in turn, generate significant EMI and can make meeting governmental regulations for EMI challenging. These regulations typically set a limit on peak energy within
  • Current Transformer Phase Shift Compensation and Calibration
    PDF, 63 Кб, Файл опубликован: 30 янв 2001
    This application report demonstrates a digital technique to compensate and calibrate the phase shift of a current (or voltage) transformer used in electric power of energy measurement. Traditional analog compensation is replaced by a digital finite impulse response (FIR) filter. A technique emulating a non-unity power factor (non-UPF) load makes the calibration fully automatic. The calibration tim
  • Economic Voltage Measurement With the MSP430 Family
    PDF, 91 Кб, Файл опубликован: 12 окт 1999
    This application report describes voltage and current measurement methods using the MSP430 universal timer/port module. The report explains the two measurement methods (charge and discharge) and shows how to measure voltage and current. The equations for the calculations are also given. Further sections show additional applications such as the measurement of two voltage inputs, bridge arrangem
  • Generation and Recognition of DTMF Signals With the Microcontroller MSP430
    PDF, 233 Кб, Файл опубликован: 1 окт 1997
    The first part of the Application Report describes the generation of DTMF signals using the Microcontroller MSP430. Following an explanation of the most important specifications which are involved, the theoretical and mathematical processes will be discussed with which sinusoidal waveforms can be derived from square-wave signals, by making use of appropriate analog filters. Tested examples of soft
  • Simple 1.5 V Boost Converter for MSP430
    PDF, 49 Кб, Файл опубликован: 18 окт 2000
    A simple, efficient, low-cost, boost converter to take 1.5 V from a single type-AA alkaline battery to the operating voltage required by the MSP430 family of ultralow-power microcontrollers is described. Expected battery life is up to 1000 hours.
  • MSP430 Family Mixed-Signal Microcontroller Application Reports
    PDF, 5.5 Мб, Файл опубликован: 21 янв 2000
    MSP430 Metering Application Report
  • MSP430 LFXT1 Oscillator Accuracy
    PDF, 184 Кб, Файл опубликован: 15 ноя 2004
    This report details the factors that influence achievable accuracy of the low frequency oscillator, specifically for real-time clock (RTC) applications. The intent of this application report is to provide an understanding of MSP430-specific factors influencing real-world achievable RTC accuracy using the LFXT1 oscillator with a standard 32.768 kHz watch crystal and present measurement data support
  • Choosing an Ultra Low-Power MCU
    PDF, 306 Кб, Файл опубликован: 30 июн 2004
    This application report describes how to compare ultralow-power MCUs. It discusses the key differences between popular low-power MCUs and how to interpret features and specifications and apply them to application requirements.
  • Wave Digital Filtering Using the MSP430
    PDF, 220 Кб, Файл опубликован: 13 сен 2006
    Digital filtering is an integral part of many digital signal processing algorithms. Digital filters are characterized as either recursive [infinite impulse response (IIR)] or non-recursive [finite impulse response (FIR)] filters. IIR filters require a smaller order for the same set of specifications compared to FIR filters, while FIR filters provide a linear phase property. However, IIR filters, i
  • FSK Modulation and Demodulation With the Microcontroller MSP430
    PDF, 110 Кб, Файл опубликован: 14 дек 1998
    This application report describes a software program for performing V.23 FSK modem transceiver functions using an MSP430 microcontroller. It makes use of novel filter architecture to perform DSP functions on a processor with only shift and add capabilities.
  • Mixing C and Assembler with the MSP430
    PDF, 168 Кб, Файл опубликован: 28 фев 2002
    This application note describes how C and assembler code can be used together within an MSP430 application. The combination of C and assembler benefits the designer by providing the power of a high-level language as well as the speed, efficiency, and low-level control of assembler.
  • CRC Implementation with MSP430
    PDF, 125 Кб, Файл опубликован: 4 ноя 2004
    Cyclic Redundancy Code (CRC) is commonly used to determine the correctness of a data transmission or storage. This application note presents a solution to compute 16-bit and 32-bit CRCs on the ultra low-power TI MSP430 microcontroller for the bitwise algorithm (low memory, low cost) and the table-based algorithm (low MIPS, low power). Both algorithms are presented in C and MSP430 assembly. Test co
  • Random Number Generation Using the MSP430
    PDF, 39 Кб, Файл опубликован: 13 окт 2006
    Many applications require the generation of random numbers. These random numbers are useful for applications such as communication protocols, cryptography, and device individualization.Generating random numbers often requires the use of expensive dedicated hardware. Using the two independent clocks available on the MSP430F2xx family of devices, it is possible to generate random numbers without s
  • Efficient Multiplication and Division Using MSP430
    PDF, 104 Кб, Файл опубликован: 3 авг 2006
  • Interfacing the MSP430 and TLC549/1549 A/D Converters
    PDF, 44 Кб, Файл опубликован: 16 ноя 2000
    This application report describes how to interface an MSP430 mixed-signal microcontroller with the TLC549 and TLV1549 3-volt A/D converters. This report is written for the MSP430x11x(1) family, but can be adapted to any MSP430 derivative.
  • Interfacing TMS320C5000 DSP to MSP430 Mixed Signal Microcontroller (Rev. A)
    PDF, 82 Кб, Версия: A, Файл опубликован: 13 окт 2000
    The TMS320C5000в„ў family of digital signal processors (DSPs) features Host Port Interface Controllers (HPI) and Direct Memory Access Controllers (DMAC) for efficient data movement without any CPU involvement. The HPI enables the DSP to interface to host processors (typically microcontrollers) bidirectionally with minimal or no external interface logic. This application report presents a hardw
  • MSP430 Capacitive Single-Touch Sensor Design Guide
    PDF, 770 Кб, Файл опубликован: 16 янв 2008
    This application report discusses the design of RC-type capacitive single-touch sensors using the MSP430 microcontroller. The MSP430 has some unique features that make it suitable for interfacing with capacitive-touch sensors. The RC-type method does not need special peripherals and can be implemented with all devices in the MSP430 product family. This method is also inherently low power and can
  • Programming a Flash-Based MSP430 Using the JTAG Interface (Rev. H)
    PDF, 19 Кб, Версия: H, Файл опубликован: 14 июл 2010
    This application report has been superseded by the document shown below. Information previously contained in this application report can be found by clicking on the following links.- MSP430 Programming Via the JTAG Interface User's Guide Download MSP430 Programming Via the JTAG Interface (PDF) Download
  • MSP430 Flash Memory Characteristics (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 14 апр 2008
    Flash memory is a widely used, reliable, and flexible nonvolatile memory to store software code and data in a microcontroller. Failing to handle the flash according to data-sheet specifications may result in unreliable operation of the application. This application report explains the physics behind these specifications and also gives recommendations for correct MSP430 flash handling. All examples
  • MSP430 Software Coding Techniques (Rev. A)
    PDF, 62 Кб, Версия: A, Файл опубликован: 17 июл 2006
    This application report covers software techniques and topics of interest to all MSP430 programmers. The first part of the document discusses the MSP430 standard interrupt-based code flow model, recommended for the vast majority of applications. The next part discusses a handful of techniques that should be considered by any developer that sets out to develop an MSP430 application. Using these met
  • MSP430 SMBus
    PDF, 128 Кб, Файл опубликован: 29 сен 1999
    This application report describes a software implementation of the system management bus (SMBus) for the MSP430 microcontroller. It includes all master protocols, an interrupt-driven slave, and master usage examples. SMBus is derived from the I2C and is commonly used in smart batteries and other system devices.
  • Tiny DCDC Converter Reference Design (Rev. A)
    PDF, 458 Кб, Версия: A, Файл опубликован: 14 июн 2010
    This reference design is presented to help application designers and others who are trying to use the MSP430 in a system with an input voltage in the range of 3.6 V to 6 V with the primary design objective to minimize solution size as well as to maintain high efficiency and long battery life.
  • Understanding MSP430 Flash Data Retention
    PDF, 475 Кб, Файл опубликован: 27 мар 2008
    The MSP430 family of microcontrollers, as part of its broad portfolio, offers both read-only memory (ROM)-based and flash-based devices. Understanding the MSP430 flash is extremely important for efficient, robust, and reliable system design. Data retention is one of the key aspects to flash reliability. In this application report, data retention for the MSP430 flash is discussed in detail and the
  • Digital Fan Control With Tachometer Using MSP430
    PDF, 82 Кб, Файл опубликован: 10 ноя 2005
    Digital Fan Control with Tachometer using MSP430 Application Report
  • Using the TPS3619 with MSP430 Microcontrollers Can Reduce Sys Power Consumption (Rev. A)
    PDF, 37 Кб, Версия: A, Файл опубликован: 19 май 2003
    The MSP430 series of microcontrollers are ideal in applications where battery life is critical. These microcontollers require only 0.1?A of current in low-power RAM retention mode; In this mode the microcontroller must have power to retain volatile memory. In some systems with charge pumps, the TPS3619 can be used to shut down the charge pump, saving system power consumption.
  • Advanced Debugging Using the Enhanced Emulation Module (EEM) With CCS v6 (Rev. F)
    PDF, 837 Кб, Версия: F, Файл опубликован: 6 сен 2016
  • Powering the MSP430 from a High Voltage Input using the TPS62122 (Rev. C)
    PDF, 330 Кб, Версия: C, Файл опубликован: 12 янв 2012
Серия: MSP430P112 (3)
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F1x
На английском языке: Datasheet Texas Instruments MSP430P112AY
