Datasheet Texas Instruments LM2852XMXAX-1.8/NOPB — Даташит
СерияLM2852
МодельLM2852XMXAX-1.8/NOPB
2A Синхронный понижающий стабилизатор 500/1500 кГц 14-HTSSOP от -40 до 125
LM2852 2A 500/1500 kHz Synchronous Buck Regulator datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 6 янв 2016
Pin1414
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка2852X1.8
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)2 A
Iq(Typ)0.85 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Synchronous Rectification,Tracking
Switching Frequency(Max)1500 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.85 В
Vout(Max)3.3 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LM2852X-1.8EVAL
    2A 500 1500kHz Synchronous SIMPLE SWITCHERВ® Buck Regulator Evaluation Module
  • Evaluation Modules & Boards: LM2852Y-2.5EVAL
  • Evaluation Modules & Boards: LM2852X-2.5EVAL
  • Evaluation Modules & Boards: LM2852X-3.3EVAL
    2A 500 1500kHz Synchronous SIMPLE SWITCHERВ® Buck RegulatorEvaluation Module
  • Evaluation Modules & Boards: LM2852Y-1.2EVAL
  • Evaluation Modules & Boards: LM2852Y-3.3EVAL
  • Evaluation Modules & Boards: LM2852Y-1.8EVAL
  • Evaluation Modules & Boards: LM2852X-1.2EVAL
  • Power Management Design for Applications Processors
    PDF, 559 Кб, Файл опубликован: 22 мар 2007
  • AN-1821 CPRI Repeater System (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report implements the Common Public Radio Interface (CPRI) for Remote Radio Heads(RRHs). The designer can use this application report for developing CPRI-based repeater systems inpoint-to-point or multi-hop configurations. This application report consists of:Designs for the CPRI SerDes Repeater Boards for the Radio Equipment (RE) and Radio EquipmentController (REC)
LM2852XMXAX1.8/NOPB, LM2852XMXAX 1.8/NOPB
На английском языке: Datasheet Texas Instruments LM2852XMXAX-1.8/NOPB
