Datasheet Texas Instruments 5962-0720701VXC — Даташит
СерияADS5444-SP
Модель5962-0720701VXC
13-разрядный аналого-цифровой преобразователь (АЦП) со скоростью 250 MSPS, класс V 84-CFP
Class V 13-Bit 250-MSPS Analog-to-Digital Converter datasheet
PDF, 532 Кб, Версия: C, Файл опубликован: 2 янв 2014
Pin84
Package TypeHFG
Industry STD TermCFP
JEDEC CodeS-CQFP-N
Package QTY1
Width (мм)19.05
Length (мм)19.05
Thickness (мм)3.68
Pitch (мм)0.64
Max Height (мм)3.68
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)4.75 В
АрхитектураPipeline
Digital Supply(Max)3.6 В
Digital Supply(Min)3 В
ENOB11.3 Bits
INL(Max)2.8 +/-LSB
InterfaceParallel LVDS
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
Power Consumption(Typ)2000 mW
RatingSpace
Reference ModeExt,Int
Разрешение13 Bits
SFDR60.5 дБ
SNR65.5 дБ
RoHSSee ti.com
  • Evaluation Modules & Boards: ADS5444EVM-CVAL
    ADS5444-SP Evaluation Module
  • High-Speed Analog-to-Digital Converter Basics
    PDF, 1.1 Мб, Файл опубликован: 11 янв 2012
    The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
Серия: ADS5444-SP (2)
  • Semiconductors > Space & High Reliability > Data Converter > Analog to Digital Converters
59620720701VXC, 5962 0720701VXC
На английском языке: Datasheet Texas Instruments 5962-0720701VXC
Публикации по теме
