Datasheet Texas Instruments UCC29002DG4 — Даташит
| Серия | UCC29002 |
| Модель | UCC29002DG4 |
Усовершенствованный 8-контактный контроллер распределения нагрузки 8-SOIC от -40 до 105
UCC2900x, UCC39002 Advanced 8-Pin Load-Share Controller datasheet
PDF, 1.2 Мб, Версия: I, Файл опубликован: 31 май 2016
Купить UCC29002DG4 на РадиоЛоцман.Цены — от 69 до 443 ₽12 предложений от 12 поставщиков IC LOAD SHARE CTRLR ADV 8SOIC. Load Share Controller PMIC 8-SOIC. PMIC - Power Management - Specialized | |||
| UCC29002DG4 Texas Instruments | 175 ₽ | ||
| UCC29002DG4 Texas Instruments | 443 ₽ | ||
| UCC29002DG4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 75 |
| Carrier | TUBE |
| Маркировка | 29002 |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Operating Supply Current | 2.5 мА |
| Operating Supply(Max) | 14.25 В |
| Operating Supply(Min) | 4.375 В |
| Рабочий диапазон температур | от -40 до 105 C |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
| Rating | Catalog |
| Share Bus | Single-Ended |
| Special Features | UVLO |
| Startup Current | 2500 uA |
- Evaluation Modules & Boards: UCC39002EVM
UCC39002 Evaluation Module
- 48-VIN, 12-VOUT Loadshare System Using the UCC39002 with Three DC-DC Modules (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 14 фев 2003
This application note features the UCC39002 BiCMOS 8-pin advanced load share controller and specifically illustrates equal current sharing between three 48-VDC to 12-VDC power modules, each rated for 8.4-A maximum output current, paralleled to supply a load of up to 24 A. The example uses high-side current sensing with the bias for the controllers supplied directly from the module?s output voltage - Pre-biased Output Voltage Startup Operation of the UCC28950PDF, 137 Кб, Файл опубликован: 1 авг 2011
- U-163 The UC3902 Load Share Controller and its Performance in Distributed Power (Rev. A)PDF, 272 Кб, Версия: A, Файл опубликован: 13 дек 2002
- U-129 UC3907 Load Share IC Simplifies Parallel Power Supply DesignPDF, 251 Кб, Файл опубликован: 5 сен 1999
The UC3907 family of Load Share Controller ICs provides all the necessary features to allow multiple independent power modules to be paralleled, so each module supplies only its proportionate share to total load current. Many power supply manufacturers have found it economically feasible to make standard modular power supplies which are easily paralleled for higher current applications. If speci
Серия: UCC29002 (10)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Load Share
