Datasheet Texas Instruments TPS54122RHLR — Даташит
Серия | TPS54122 |
Модель | TPS54122RHLR |
Регулятор QuietSupply™ 3A со встроенным преобразователем постоянного тока и малошумящим LDO 24-VQFN от -40 до 150
TPS54122 3-A, QuietSupply Regulator With Integrated DC-DC Converter and Low-Noise LDO datasheet
PDF, 2.4 Мб, Версия: C, Файл опубликован: 20 июл 2017
Pin | 24 |
Package Type | RHL |
Industry STD Term | VQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | PZFQ |
Width (мм) | 3.5 |
Length (мм) | 5.5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Control Mode | Current Mode |
Duty Cycle(Max) | 98 % |
Iout(Max) | 3 A |
Iq(Typ) | 0.36 мА |
Рабочий диапазон температур | от -40 до 150 C |
Package Group | VQFN |
Rating | Catalog |
Regulated Outputs | 2 |
Special Features | Enable,Power Good |
Switching Frequency(Max) | 2000 kHz |
Switching Frequency(Min) | 300 kHz |
Тип | Converter |
Vin(Max) | 6 В |
Vin(Min) | 2.95 В |
Vout(Max) | 4.5 В |
Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: TPS54122EVM-201
TPS54122EVM-201 EVM with a dual output regulator and a 3A switcher output and a 3A Quiet Supply
- Design Procedure for the TPS54122PDF, 386 Кб, Файл опубликован: 4 ноя 2013
This application report details the design procedure of a low-noise, 3-A power supply with the integratedswitcher and low-dropout (LDO) regulator of the TPS54122. The designer must know a few parameters inorder to start the design process and typically determines them at the system level. - A Topical Index of TI LDO Application Notes (Rev. F)PDF, 82 Кб, Версия: F, Файл опубликован: 27 июн 2019
Серия: TPS54122 (2)
- TPS54122RHLR TPS54122RHLT
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
