Datasheet Texas Instruments SN74AUC2G34DCKR — Даташит
СерияSN74AUC2G34
МодельSN74AUC2G34DCKR
Двойной буферный вентиль 6-SC70 от -40 до 85
SN74AUC2G34 datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 15 янв 2007
Pin666
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаU9RU9FU95
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
3-State OutputNo
Bits2
F @ Nom Voltage(Max)250 Mhz
Gate TypeBUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)6.4,3.4,2.3,1.6,1.2 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC2G34DCKR
