Datasheet Texas Instruments SN74CBTS3384DBQR — Даташит
Серия | SN74CBTS3384 |
Модель | SN74CBTS3384DBQR |
10-битный переключатель шины на полевом транзисторе с ограничением на диоде Шоттки 24-SSOP от -40 до 85
SN74CBTS3384 datasheet
PDF, 874 Кб, Версия: M, Файл опубликован: 9 июл 2003
Pin | 24 |
Package Type | DBQ |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | CBTS3384 |
Width (мм) | 3.9 |
Length (мм) | 8.65 |
Thickness (мм) | 1.5 |
Pitch (мм) | .64 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Schottky clamp diode to prevent undershoot |
Полоса частот | 200 МГц |
Configuration | 1:1 SPST |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 6.5 пФ |
Количество каналов | 10 |
OFF-state leakage current(Max) | 1 мкА |
ON-state leakage current(Max) | 150 мкА |
Package Group | SSOP |
Package Size: mm2:W x L | 24SSOP: 52 mm2: 6 x 8.65(SSOP) PKG |
Rating | Catalog |
Ron(Max) | 20 Ohms |
Ron(Typ) | 5 Ohms |
Supply Current(Max) | 3 uA |
Supply Range | 5.5 Max |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 4 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- SN74CBTS3384 Bus Switches Provide Fast Connection and Ensure Isolation (Rev. A)PDF, 46 Кб, Версия: A, Файл опубликован: 1 авг 1996
Buses are the pathways for communication between the CPU, memory, and I/O ports in electronic systems. The SN74CBTS3384 bus switch provides a high-speed, low-power solution to bus connections while providing a reliable solution to bus isolation. This document describes the mechanics of MOSFET switches which can lead to false switching and disruption of the bus. The SN74CBTS3384 solution to theses - Flexible Voltage-Level Translation With CBT Family DevicesPDF, 40 Кб, Файл опубликован: 20 июл 1999
Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency. - 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not - 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
- VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CBTS3384 (10)
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
