Datasheet Texas Instruments UCC2897ARGPT — Даташит
СерияUCC2897A
МодельUCC2897ARGPT
Усовершенствованный ШИМ-контроллер с активным ограничением тока в режиме тока 20-QFN от -40 до 125
UCC2897A Advanced Current-Mode Active-Clamp PWM Controller datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 3 июн 2011
Pin20
Package TypeRGP
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка2897A
Width (мм)4
Length (мм)4
Thickness (мм).93
Pitch (мм).5
Max Height (мм)1
Control MethodCurrent
Duty Cycle(Max)74 %
Frequency(Max)1000 kHz
Gate Drive(Typ)2 A
Package GroupQFN
Special FeaturesHV Start-up,Input Line Monitor,Programmable Slope Compensation,Soft Start,Soft Switching
TopologyActive-Clamp Forward,Forward
UVLO Thresholds On/Off12.7/~8 В
Vin(Max)110 В
Vin(Min)18 В
  • Evaluation Modules & Boards: UCC2897AEVM
    UCC2897A Evaluation Module
  • Evaluation Modules & Boards: TPS2373-4EVM-758
    TPS2373 Evaluation Module for IEEE802.3bt PoE PD Applications
  • UCC2897A Peak Current Mode Active Clamp Forward Converter Small Signal Modeling
    PDF, 748 Кб, Файл опубликован: 17 янв 2014
  • External Slope Compensation for UCC2897A in Some Special Applications
    PDF, 192 Кб, Файл опубликован: 5 янв 2010
  • Understanding and Designing an Active Clamp Current Mode Controlled Converter
    PDF, 845 Кб, Файл опубликован: 6 май 2010
    The UCC2897A Current Mode Active Clamp PWM Controller offers a highly integrated feature set resulting in precision control required for an active clamp forward or flyback converter. The UCC2897A data sheet contains all the design details necessary for accurately programming the device. However, there are significant design considerations and trade-offs unique to the active clamp power stage that
  • Method of Providing Hiccup Operation for UCC2897AEVM
    PDF, 361 Кб, Файл опубликован: 27 авг 2009
    This application note is to provide users of the UCC2897AEVM with a method of generating acyclic restart or restart attempt of the EVM should the converter encounter an overcurrent condition including an output short.
Серия: UCC2897A (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC2897ARGPT
