Линейка продуктов KEEN SIDE
Datasheet Texas Instruments OPA552FA — Даташит
СерияOPA552
МодельOPA552FA
Высоковольтные сильноточные операционные усилители 7-ДДПАК/ТО-263
OPA55x High-Voltage, High-Current Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 7 янв 2016
Pin7
Package TypeKTW
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
Width (мм)8.89
Length (мм)10.1
Thickness (мм)4.44
Max Height (мм)4.65
Рекомендуемая замена
ReplacementOPA552FAKTWT
Replacement CodeS
Additional FeaturesDecompensated
Approx. Price (US$)1.75 | 1ku
АрхитектураFET
CMRR(Min)(dB)92
CMRR(Typ)(dB)102
GBW(Typ)(MHz)12
Input Bias Current(Max)(pA)100
Iq per channel(Max)(mA)8.5
Iq per channel(Typ)(mA)7
Number of Channels(#)1
Offset Drift(Typ)(uV/C)7
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)380
Package GroupDDPAK/TO-263
Rail-to-RailNo
Slew Rate(Typ)(V/us)24
Total Supply Voltage(Max)(+5V=5, +/-5V=10)60
Total Supply Voltage(Min)(+5V=5, +/-5V=10)8
Vos (Offset Voltage @ 25C)(Max)(mV)3
RoHSНе совместим
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Optoelectronics Circuit Collection
    PDF, 261 Кб, Файл опубликован: 11 июн 2001
    This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA552FA
