Datasheet Texas Instruments REG113EA-5/250G4 — Даташит
СерияREG113
МодельREG113EA-5/250G4
400 мА, малошумящий стабилизатор с малым падением напряжения 8-VSSOP от -40 до 85
DMOS 400mA Low-Dropout Regulator datasheet
PDF, 965 Кб, Версия: D, Файл опубликован: 8 сен 2005
Package TypeDGK
Industry STD TermVSSOP
Package QTY250
CarrierSMALL T&R
МаркировкаR13B
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Точность3 %
Fixed Output Options2.5,2.85,3,3.3,5 В
Iout(Max)0.4 A
Iq(Typ)0.4 мА
Noise28 uVrms
Output Capacitor TypeCap Free,Ceramic
Output OptionsFixed Output
PSRR @ 100KHz28 дБ
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Regulated Outputs1
Special FeaturesEnable,Foldback Overcurrent Protection
Thermal Resistance ОёJA160 В°C/W
Vdo(Typ)250 мВ
Vin(Max)10 В
Vin(Min)2.7 В
Vout(Max)5 В
Vout(Min)2.5 В
  • Evaluation Modules & Boards: TPS79328EVM
    TPS79328 Evaluation Module
  • Evaluation Modules & Boards: TPS76933EVM-127
    SOT23 LDO, 5 V to 1.0 V, 100mA output power supply
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible With Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Package
  • Evaluation Modules & Boards: TPS76901EVM-127
    SOT23 LDO, 5 V to 1.8 V, 100mA output power supply
  • Evaluation Modules & Boards: TPS79301EVM
    TPS79301 Evaluation Module
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
REG113EA5/250G4, REG113EA 5/250G4
На английском языке: Datasheet Texas Instruments REG113EA-5/250G4
