Datasheet Texas Instruments SN74AVC6T622PWR — Даташит
СерияSN74AVC6T622
МодельSN74AVC6T622PWR
Аудиокодек AC'97 Трансивер преобразования напряжения 20-TSSOP от -40 до 85
Audio Codec AC'97 Voltage-Translation Transceiver datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 24 мар 2009
29 предложений от 16 поставщиков
Микросхема Преобразователь напряжения и электроуровня, TEXAS INSTRUMENTS SN74AVC6T622PWR Voltage Interface Transceiver, AVC Family, 6Input, 16mA, 2.7ns, 1.2V to 3.6V, TSSOP-20
SN74AVC6T622PWR
50 ₽
SN74AVC6T622PWR
от 120 ₽
Hi-Tech Circuit Group
SN74AVC6T622PWR
SN74AVC6T622PWR
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаWU622
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Bits6
ICCA Static Current0.01 мА
ICCB Static Current0.01 мА
Package GroupTSSOP
Special FeaturesAC'97
Static Current0.015 мА
VCCA(Max)3.6 В
VCCA(Min)1.2 В
VCCB(Max)3.6 В
VCCB(Min)1.2 В
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVC6T622 (3)
  • Semiconductors > Logic > Voltage Level Translation > Application Specific Voltage Translation
На английском языке: Datasheet Texas Instruments SN74AVC6T622PWR
