Datasheet Texas Instruments TLV2217-18KTPR — Даташит
Серия | TLV2217 |
Модель | TLV2217-18KTPR |
TLV2217 Low-Dropout Fixed-Voltage Regulators datasheet
PDF, 1.2 Мб, Версия: M, Файл опубликован: 18 ноя 2016
![]() 11 предложений от 10 поставщиков IC REG LIN 1.8V 500MA 2POWERFLEX. Linear Voltage Regulator IC 1 Output 500mA 2-PowerFLEXTM. PMIC - Voltage Regulators - Linear... | |||
TLV2217-18KTPR Texas Instruments | от 73 ₽ | ||
TLV2217-18KTPR Texas Instruments | по запросу | ||
Pin | 2 |
Package Type | KTP |
Industry STD Term | PFM |
JEDEC Code | R-PSFM-G |
Маркировка | 2217-18 |
Width (мм) | 6.15 |
Length (мм) | 6.04 |
Thickness (мм) | 1.91 |
Pitch (мм) | 4.57 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
Accuracy(%) | 2 |
Additional Features | Overcurrent Protection Thermal Shutdown |
Approx. Price (US$) | 0.33 | 1ku |
Fixed Output Options(V) | 1.8 2.5 3.3 |
Iout(Max)(A) | 0.5 |
Iq(Typ)(mA) | 2 |
Operating Temperature Range(C) | 0 to 125 |
Output Capacitor Type | Non-Ceramic |
Output Options | Fixed Output |
Package Group | TO-220 TO-252 TSSOP |
Package Size: mm2:W x L (PKG) | See datasheet (TO-220) See datasheet (CDIP) See datasheet (PFM) |
Rating | Catalog |
Regulated Outputs(#) | 1 |
Vdo(Typ)(mV) | 500 |
Vin(Max)(V) | 12 |
Vin(Min)(V) | 3 |
Vout(Max)(V) | 3.3 |
Vout(Min)(V) | 1.8 |
RoHS | Не совместим |
- Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
Серия: TLV2217 (19)
TLV221718KTPR, TLV2217 18KTPR
