Datasheet Texas Instruments LM3431AQMHX/NOPB — Даташит
СерияLM3431-Q1
МодельLM3431AQMHX/NOPB
3-канальный светодиодный драйвер постоянного тока со встроенным повышающим контроллером 28-HTSSOP от -40 до 125
LM3431/31A/31Q/31AQ 3-Chan Constant Current LED Driver w/Integrated Boost Cntr datasheet
PDF, 1.9 Мб, Версия: G, Файл опубликован: 2 май 2013
IC LED DRIVER CTRLR DIM 28HTSSOP. LED Driver IC 3 Output DC DC Controller Step-Up (Boost) Analog, PWM Dimming 28-HTSSOP. PMIC...
LM3431AQMHX/NOPB
105 ₽
LM3431AQMHX/NOPB
198 ₽
LM3431AQMHX/NOPB
LM3431AQMHX/NOPB
Pin2828
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаAQMHLM3431
Width (мм)4.44.4
Length (мм)9.79.7
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
ApplicationsBacklight,Stop/Tail,Turn
Количество каналов3
Iout(Max)0.6 A
Iq(Typ)4 мА
LED Current Per Channel200 мА
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
RatingAutomotive
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Soft Start,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)200 kHz
TopologyBoost with Current Sink
Vin(Max)36 В
Vin(Min)4.5 В
Vout(Max)40 В
Vout(Min)5.5 В
  • Evaluation Modules & Boards: LM3431EVAL
    Evaluation Board for the 3-Channel Constant Current LED Driver with Integrated Boost Controller
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • Semiconductors > Power Management > LED Driver > Automotive LED Driver
На английском языке: Datasheet Texas Instruments LM3431AQMHX/NOPB
Публикации по теме
