Datasheet Texas Instruments TMS320C6678AGYPA — Даташит
СерияTMS320C6678
МодельTMS320C6678AGYPA
TMS320C6678 Multicore Fixed and Floating-Point Digital Signal Processor datasheet
PDF, 2.2 Мб, Версия: E, Файл опубликован: 6 мар 2014
Pin841841841
Package TypeGYPGYPGYP
Package QTY444444
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаA@2010 TITMS320C6678GYP
Width (мм)242424
Length (мм)242424
Thickness (мм)2.812.812.81
ApplicationsCommunications and Telecom
DRAMDDR3
DSP8 C66x
DSP MHz1000,1250 Max.
EMAC2-Port 1Gb Switch
GFLOPS128,160
On-Chip L2 Cache4096 KB
Рабочий диапазон температурот -40 до 100,0 до 85 C
Other On-Chip Memory4096 KB
PCI/PCIe2 PCIe Gen2
Package Size: mm2:W x LSee datasheet (FCBGA) PKG
Serial I/OI2C,RapidIO,SPI,TSIP,UART
Serial RapidIO1 (four lanes)
Total On-Chip Memory8832 KB
RoHSSee ti.com
  • Development Kits: HL5CABLE
    Hyperlink Cable
  • Development Kits: TMDSEVM6678
    TMS320C6678 Evaluation Modules
  • Daughter Cards: TMDXEVMPCI
    AMC to PCIe Adapter Card
    XDS200 USB Debug Probe
  • PCI Express (PCIe) Resource Wiki for Keystone Devices (Rev. A)
    PDF, 57 Кб, Версия: A, Файл опубликован: 19 май 2017
  • Keystone NDK FAQ
    PDF, 54 Кб, Файл опубликован: 3 окт 2016
    This document is a collection of frequently asked questions (FAQ) on running the NDK examples on the KeyStoneв„ў family of devices.
  • TI Keystone DSP Hyperlink SerDes IBIS-AMI Models
    PDF, 3.2 Мб, Файл опубликован: 9 окт 2014
    This document describes the organization, structure, and proper usage of the TI serializer and deserializer (SerDes) IBIS-AMI models for Keystone DSP Hyperlink interface.
  • TI Keystone DSP PCIe SerDes IBIS-AMI Models
    PDF, 4.8 Мб, Файл опубликован: 9 окт 2014
    This document describes the organization, structure, and proper usage of the TI serializer and deserializer (SerDes) IBIS-AMI models for Keystone DSP PCIe interface.
  • SerDes Implementation Guidelines for KeyStone I Devices
    PDF, 590 Кб, Файл опубликован: 31 окт 2012
    The goal of KeyStone I SerDes collateral material is to make system implementation easier for the customer by providing the system solution. For these SerDes-based interfaces, it is not assumed that the system designer is familiar with the industry specifications, SerDes technology, or RF/microwave PCB design. However, it is still expected that the PCB design work will be supervised by a knowledge
  • Hardware Design Guide for KeyStone Devices (Rev. C)
    PDF, 1.7 Мб, Версия: C, Файл опубликован: 15 сен 2013
  • KeyStone I DDR3 Initialization (Rev. E)
    PDF, 114 Кб, Версия: E, Файл опубликован: 28 окт 2016
    The initialization of the DDR3 DRAM controller on KeyStone I DSPs is straightforward as long as the proper steps are followed. However, if some steps are omitted or if some sequence-sensitive steps are implemented in the wrong order, DDR3 operation will be unpredictable.All DDR3 initialization routines must contain the basic register writes to configure the memory controller within the DSP
  • TMS320C66x DSP Generation of Devices (Rev. A)
    PDF, 245 Кб, Версия: A, Файл опубликован: 25 апр 2011
  • AN-1281 Bumped Die (Flip Chip) Packages (Rev. A)
    PDF, 2.2 Мб, Версия: A, Файл опубликован: 1 май 2004
    Application Note 1281 Bumped Die (Flip Chip) Packages
  • SERDES Link Commissioning on KeyStone I and II Devices
    PDF, 138 Кб, Файл опубликован: 13 апр 2016
    The serializer-deserializer (SerDes) performs serial-to-parallel conversions on data received from a peripheral device and parallel-to-serial conversion on data received from the CPU. This application report explains the SerDes transmit and receive parameters tuning, tools and some debug techniques for TI Keystone I and Keystone II devices.
  • PCIe Use Cases for KeyStone Devices
    PDF, 320 Кб, Файл опубликован: 13 дек 2011
  • Clocking Design Guide for KeyStone Devices
    PDF, 1.5 Мб, Файл опубликован: 9 ноя 2010
  • Optimizing Loops on the C66x DSP
    PDF, 585 Кб, Файл опубликован: 9 ноя 2010
  • The C6000 Embedded Application Binary Interface Migration Guide (Rev. A)
    PDF, 20 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    The C6000 compiler tools support a new ELF-based ABI named EABI. Prior to this time, the compiler only supported a single ABI, which is now named COFF ABI. The following compelling best-in-class features are available under the C6000 EABI:GeneralZero-init globals: “int gvar;” gets set to 0 before main runs.Dynamic linking: Add code to a running system.Native ROM
  • DDR3 Design Requirements for KeyStone Devices (Rev. B)
    PDF, 582 Кб, Версия: B, Файл опубликован: 5 июн 2014
  • Multicore Programming Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
    As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicore
  • Processor SDK RTOS Audio Benchmark Starter Kit
    PDF, 530 Кб, Файл опубликован: 12 апр 2017
    The TI TMS320C6000в„ў Digital Signal Processors (DSPs) have many architectural advantages that make them ideal for computation-intensive real-time applications that are commonly used in audio processing application. This application notes describes Audio Benchmark Starterkit software that is intended to provide an easy and quick way to benchmark key audio functions on C66x and C674x DSP device
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > C66x DSP
На английском языке: Datasheet Texas Instruments TMS320C6678AGYPA
