Datasheet Texas Instruments LMT70AYFQR — Даташит
СерияLMT70A
МодельLMT70AYFQR
В±0.1В°C Matching Accuracy Precision Analog Temperature Sensor 4-DSBGA -55 to 150
LMT70, LMT70A В±0.05В°C Precision Analog Temperature Sensor, RTD and Precision NTC Thermistor IC datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 11 май 2015
52 предложений от 17 поставщиков
SENSOR ANALOG -55C-150C 4DSBGA. Temperature Sensor Analog, Local -55°C ~ 150°C 5.194mV/°C 4-DSBGA (0.81x0.81). Temperature Sensors - Analog and Digital Output...
LMT70AYFQR
168 ₽
LMT70AYFQR
от 251 ₽
Эиком
LMT70AYFQR
от 265 ₽
LMT70AYFQR
от 267 ₽
Pin4
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY3000
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
InterfaceAnalog Output
Local Sensor Accuracy(Max)0.36 +/- C
Рабочий диапазон температурот -55 до 150 C
Output Impedance80 Ohm
Package GroupDSBGA
Sensor Gain-5.19 mV/Deg C
Supply Current(Max)12 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2 В
  • Evaluation Modules & Boards: LMT70EVM
    LMT70 Evaluation Module Precise Analog Output Temperature Sensor with Output Enable
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
Серия: LMT70A (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT70AYFQR
