Datasheet Texas Instruments TXB0102DCURG4 — Даташит
СерияTXB0102
МодельTXB0102DCURG4
2-битный двунаправленный переключатель уровня напряжения с автоматическим определением направления и защитой от электростатического разряда +/-15 кВ 8-VSSOP от -40 до 85
TXB0102 2-Bit Bidirectional Voltage-Level Translator With Auto Direction Sensing and В±15-kV ESD Protection datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 11 дек 2014
Pin8888
Package TypeDCUDCUDCUDCU
Industry STD TermVSSOPVSSOPVSSOPVSSOP
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY3000300030003000
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&R
МаркировкаNFDQNZNFDRFD
Width (мм)2222
Length (мм)2.32.32.32.3
Thickness (мм).85.85.85.85
Pitch (мм).5.5.5.5
Max Height (мм).9.9.9.9
3-State OutputNo
Bits2
F @ Nom Voltage(Max)50 Mhz
Gate TypeN/A
ICC @ Nom Voltage(Max)0.005 мА
LogicTrue
Output Drive (IOL/IOH)(Max)0.02/-0.02 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 6 mm2: 3.1 x 2(VSSOP) PKG
Schmitt TriggerNo
Special FeaturesOne-Shot Edge Accelerators,Bidirectional
Sub-FamilyDual Supply Translator
Technology FamilyTXB
VCC(Max)5.5 В
VCC(Min)1.2 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.9 нс
RoHSSee ti.com
  • A Guide to Voltage Translation With TXB-Type Translators
    PDF, 102 Кб, Файл опубликован: 3 мар 2010
    Modern trends are driving the need for lower supply voltages across many system-level designs. As most processor voltage levels continue to decrease in the interest of achieving the lowest possible power consumption, peripheral devices maintain a need for higher voltage levels, creating potential for voltage discontinuities within a system. To remedy this mixed voltage system incompatibility, a vo
  • Effects of pullup and pulldown resistors on TXS and TXB devices
    PDF, 732 Кб, Файл опубликован: 20 сен 2017
    The TXS and TXB family of devices belong to the auto-bidirectional translation products from TI. These devices can be sensitive to external pullup or pulldown resistors due to the internal pullup resistors present in the TXS device and the internal serial resistors present in the TXB device. In this application note, the effects of external pullup and pulldown resistors on VOL and VOH levels of th
  • A Guide to Voltage Translation With TXS-Type Translators
    PDF, 287 Кб, Файл опубликован: 29 июн 2010
Серия: TXB0102 (5)
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments TXB0102DCURG4
