Клеммники KEEN SIDE
Datasheet Texas Instruments TMX320VC5502PGF200 — Даташит
СерияTMS320VC5502
МодельTMX320VC5502PGF200
Процессор цифровых сигналов с фиксированной точкой 176-LQFP от -40 до 85
TMS320VC5502 Fixed-Point Digital Signal Processor datasheet
PDF, 2.0 Мб, Версия: K, Файл опубликован: 20 ноя 2008
Pin176
Package TypePGF
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Width (мм)24
Length (мм)24
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ApplicationsAudio
Automotive
Communications and Telecom
Consumer Electronics
Industrial
Approx. Price (US$)6.83 | 1ku
DRAMSDRAM
DSP1 C55x
DSP MHz (Max.)200
300
HPI1 16-bit HPI
I2C1
McBSP3
Operating SystemsDSP/BIOS
VLX
Operating Temperature Range(C)-40 to 85
UART(SCI)1
RoHSНе совместим
  • Evaluation Modules & Boards: TMDX5502EZDSP
    C5502 eZdsp Development Kit
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • TMS320VC5502 Hardware Designer's Resource Guide
    PDF, 177 Кб, Файл опубликован: 22 июл 2004
    The DSP Hardware Designer's Resource Guide is organized by development flow and functional areas to make your design effort as seamless as possible. Topics covered include getting started, board design, system testing, and checklists to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, models, symbols, and refere
  • Migrating from TMS320VC5402A to TMS320VC5502
    PDF, 322 Кб, Файл опубликован: 21 ноя 2003
    This document describes issues of interest related to migration from the TMS320VC5402A to the TMS320VC5502. The objective of this document is to indicate differences between the two devices. Functions that are identical between the two devices are not included. For detailed information on the specific functions of either device, refer to the following data manuals and reference guides: TMS320VC
  • Using the TMS320VC5501/5502 Bootloader (Rev. C)
    PDF, 439 Кб, Версия: C, Файл опубликован: 19 окт 2004
    This document describes the features of the on-chip bootloader provided with the TMS320VC5501 and TMS320VC5502 digital signal processors (DSPs). Included are descriptions of each of the available boot modes and any interfacing requirements associated with them, instructions on generating the boot table, and information on the different versions of the bootloader.This document contains prelimina
  • Achieving Efficient Memory System Performance w/ I-Cache on the TMS320VC5501/02 (Rev. A)
    PDF, 265 Кб, Версия: A, Файл опубликован: 24 июн 2004
    The TMS320VC5501 and TMS320VC5502 were designed as low cost DSPs for low cost real-time solutions. In order to achieve the best performance with these processors the system designer must follow the guidelines provided in the application report.Execute code from external memory with the on-chip I-Cache enabled.Locate data in internal memory at run time.Use the External Memory I
  • TMS320VC5501, TMS320VC5502 Power Consumption Summary (Rev. A)
    PDF, 66 Кб, Версия: A, Файл опубликован: 13 дек 2016
  • Migrating from TMS320VC5510 to TMS320VC5502
    PDF, 187 Кб, Файл опубликован: 28 фев 2003
    This document describes issues of interest related to migration from the TMS320VC5510 to the TMS320VC5502. The objective of this document is to indicate differences between the two devices. Functions that are identical between the two devices are not included. For detailed information on the specific functions of either device, refer to the following data manuals and reference guides: the TMS320VC
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments TMX320VC5502PGF200
