Оптопары и оптореле Megawin
Datasheet Texas Instruments TLV5590ED — Даташит
СерияTLV5590
МодельTLV5590ED
2-битный АЦП для набора микросхем пейджера FLEX™ 14-SOIC от 0 до 70
Datasheet
TSP
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Minimizing Input Design Problems With The TLV5590
    PDF, 107 Кб, Файл опубликован: 1 фев 1998
    Difficulty receiving messages on phases B and D of the FLEXTM signal while successfully receiving messages on Phases A and C usually indicates the receiver audio output is not properly interfaced to the TLV5590. The FLEX chipset requires proper consideration of the TLV5590 input interface to insure the correct digital conversion of the demodulated 4 Level FSK (Frequency Shift Keying) audio output
  • Using References to Generate Offsets for the TLC55xx Family Data Converters (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 29 июл 2002
    This application report describes the process for using references to generate offsets for Texas Instrument?s TLC55XX family data converters.
Серия: TLV5590 (2)
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
На английском языке: Datasheet Texas Instruments TLV5590ED
