Datasheet Texas Instruments ADS8325IDRBR — Даташит
СерияADS8325
МодельADS8325IDRBR
16-разрядный последовательный выход с частотой дискретизации 100 кSPS, микромощность от 2,7 до 5,5 В, дискретизация АЦП 8-SON от -40 до 85
16-Bit, High-Speed, 2.7V to 5V microPower Sampling A/D Converter datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 13 авг 2007
Package TypeDRB
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY2500
МаркировкаB25
Width (мм)3
Length (мм)3
Thickness (мм).88
Max Height (мм)1
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)4 +/-LSB
Input Range(Max)5.5 В
Тип входаPseudo-Differential,Single-Ended
Integrated FeaturesN/A
InterfaceSerial,SPI
Multi-Channel ConfigurationN/A
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Power Consumption(Typ)2.25 mW
Reference ModeExt
Разрешение16 Bits
SINAD91 дБ
SNR91 дБ
Sample Rate (max)100kSPS SPS
Sample Rate(Max)0.1 MSPS
THD(Typ)-106 дБ
  • Evaluation Modules & Boards: ADS8325EVM-PDK
    ADS8325 Performance Development Kit
  • Matching the noise performance of the operational amplifier to the ADC
    PDF, 204 Кб, Файл опубликован: 18 апр 2006
  • Interfacing the ADS8320/ADS8325 to TMS320C6711 DSP
    PDF, 326 Кб, Файл опубликован: 27 июн 2003
    This application note presents a method for interfacing the ADS8320/ADS8325 16-bit 100 KSPS SAR analog-to-digital converter to the TMS320C6711 DSP. Software developed for use in this application reads continuously from the converter. Explained within is how to use the BIOS/CSL and the configuration tool in Code Composer Studio? to set the McBSP and hardware interrupt vectors. The software can also
  • High-Voltage Signal Conditioning for Differential ADCs
    PDF, 125 Кб, Файл опубликован: 14 июн 2004
    Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design,
  • Interfacing the MSOP8EVM to TMS320C6x Processors
    PDF, 219 Кб, Файл опубликован: 2 дек 2003
    The modular MSOP8EVM is an evaluation module for single-channel, low-power, 8 to 16-bit serial analog-to-digital converters. This application note presents a method for interfacing this EVM to the TMS320C6x Series DSKs using a 5-6K Interface Board. The EVM software provides compile options to choose the proper data formatting for the ADS7816, ADS7817, ADS7818, ADS7822, ADS7826, ADS7829, ADS7835, A
  • Interfacing the MSOP8EVM to TMS320C5x Processors
    PDF, 225 Кб, Файл опубликован: 28 апр 2004
    This application note presents a method for interfacing the modular MSOP8 evaluation module (EVM), an EVM for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters, to the TMS320C5x series DSKs using a 5-6K interface board. The software developed provides compile options to choose the proper data formatting for the ADS7816, ADS7817, ADS7818, ADS7822, ADS7826, ADS7827, ADS7829
  • Interfacing the MSOP8EVM to MSP430 Processors
    PDF, 54 Кб, Файл опубликован: 28 июл 2004
    This application note presents a method for interfacing the modular MSOP8EVM - an EVM for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters - to the MSP430 series microcontrollers. The hardware used for this example includes the HPA449 from SoftBaugh, Inc. (www.softbaugh.com), featuring the MSP430F449. The software developed provides compile options to choose the proper d
  • Interfacing the MSOP8EVM to TMS470 Processors
    PDF, 68 Кб, Файл опубликован: 15 мар 2006
    This application report presents a method for interfacing the modular MSOP8EVM, an evaluation module (EVM) for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters to the TMS470 series microcontrollers. The hardware used for this example includes the TMS470 Kickstart Development Kit evaluation kit featuring the 60-MHz TMS470R1B1M and the HPA-MCU Interface Board. The soft
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
На английском языке: Datasheet Texas Instruments ADS8325IDRBR
