Datasheet Texas Instruments TPS24750RUVR — Даташит
СерияTPS24750
МодельTPS24750RUVR
18V, 12A, 3mО© eFuse with IMON and PG 36-VQFN -40 to 85
TPS2475x 12-A eFuse Circuit Protector with Current Monitor datasheet
PDF, 2.1 Мб, Версия: B, Файл опубликован: 29 сен 2016
Pin36
Package TypeRUV
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаTPS24750
Width (мм)3.5
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Channel(s) Controlled1
Current Limit AccuracyN/A
Current Limit Function EnabledStartup Only
Current Limit TypeAdjustable
Current Limit(Max)12 A
Current Limit(Min)0.01 A
FET ProtectionSOA
Fault ResponseLatch Off
Imax12 A
Количество каналов1
ON_OFF Control InputENUV s
Overcurrent ResponseCurrent Limiting
Overvoltage ResponseCutoff
Package GroupVQFN
Package Size: mm2:W x L36VQFN: 25 mm2: 7 x 3.5(VQFN) PKG
Rise Time(Typ)800 us
Ron(Typ)3 mOhm
Special FeaturesCurrent Sense/Monitor,Fault Reporting,Overvoltage Protection,Power Good,Reverse Current Protection,Thermal Shutdown,Under Voltage Lock Out
UL RecognitionNo
Vabsmax_cont30 В
Vin(Max)18 В
Vin(Min)2.5 В
  • Evaluation Modules & Boards: TPS24750EVM-546
    12A Integrated Hot-Swap Protector with Current Monitor
Серия: TPS24750 (2)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
На английском языке: Datasheet Texas Instruments TPS24750RUVR
