Datasheet ТI DRV8312DDW — Даташит
СерияDRV8312
МодельDRV8312DDW
Datasheet Texas Instruments DRV8312DDW
Драйвер трехфазного бесщеточного двигателя постоянного тока 6,5 А с защитой от бросков тока (PWM Ctrl) 44-HTSSOP от -40 до 85
DRV83x2 Three-Phase PWM Motor Driver datasheet
PDF, 2.5 Мб, Версия: E, Файл опубликован: 31 дек 2014
  • Hardware Design Considerations for an Electric Bicycle using BLDC Motor
    PDF, 530 Кб, Файл опубликован: 11 июн 2014
    A traditional bicycle is a two-wheel vehicle that is propelled by the rider who delivers muscle power through pedals that rotate one of the two wheels. The rider steers the front wheel to create a force that returns and maintains the vehicle center of gravity into a stable zone whenever necessary, thus keeping the bicycle upright. An electric bicycle carries batteries that deliver electric power t
  • Hardware Design Considerations for an Efficient Vacuum Cleaner using BLDC Motor (Rev. A)
    PDF, 213 Кб, Версия: A, Файл опубликован: 15 июл 2015
    A vacuum cleaner is a device that uses an air pump to create a partial vacuum to suck up dirt and dust particles from a given surface. Vacuum cleaners are used in homes as well as in industries and come with a variety of power levels, small battery-operated hand-held devices, domestic central vacuum cleaners and huge stationary industrial appliances. A universal motor is typically used as suction
  • Sensored 3-Phase BLDC Motor Control Using MSP430
    PDF, 199 Кб, Файл опубликован: 20 июл 2011
    Brushless DC (BLDC) motors are electronically commutated motors that offer many advantages over brushed DC motors and, therefore, are becoming very popular industrially and commercially. This application report discusses a sensored 3-phase BLDC motor control solution using MSP430в„ў as the motor controller. Hall sensors are used to detect the rotor position and close the commutation loop. Both open
  • InstaSPIN(tm) BLDC Lab
    PDF, 1.4 Мб, Файл опубликован: 15 ноя 2011
    For this lab we are using the Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU (DRV8312-C2-KIT) (the DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can also be used) with a Piccolo F28035 controlCARD subsystem to run the sensorless InstaSPIN BLDC technique.These are the tasks that must be done to spin motors:Make sure all physical connections and jumper settings on the kit
Серия: DRV8312 (2)
  • Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Drivers with FETs
На английском языке: Datasheet Texas Instruments DRV8312DDW
Политика конфиденциальности
