Datasheet Texas Instruments SN74AUC2G02DCTR — Даташит
СерияSN74AUC2G02
МодельSN74AUC2G02DCTR
ДВОЙНОЙ 2-ВХОДНОЙ ПОЛОЖИТЕЛЬНО-НЕ-ВОРОТ 8-SM8 от -40 до 85
SN74AUC2G02 datasheet
PDF, 942 Кб, Версия: C, Файл опубликован: 11 янв 2007
Pin888
Package TypeDCTDCTDCT
Industry STD TermSSOPSSOPSSOP
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаZU02R
Width (мм)2.82.82.8
Length (мм)2.952.952.95
Thickness (мм)1.291.291.29
Pitch (мм).65.65.65
Max Height (мм)1.31.31.3
3-State OutputNo
Bits2
F @ Nom Voltage(Max)250 Mhz
Gate TypeNOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSM8
Package Size: mm2:W x L8SM8: 12 mm2: 4 x 2.95(SM8) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyNOR Gate
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)8,3.5,2.2,1.8,1.3 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC2G02DCTR
