Datasheet ТI THS1206IDAG4 — Даташит
| Серия | THS1206 |
| Модель | THS1206IDAG4 |
12-разрядный четырехканальный АЦП, 6 MSPS.
THS1206: 12-Bit, 6 MSPS, Simultaneous Sampling Analog-to-Digital Converter datasheet
PDF, 1.1 Мб, Версия: H, Файл опубликован: 27 июн 2003
(Конфиг.), DSP/uP IF, Интегр. 16x FIFO, автоматическое сканирование каналов, малое энергопотребление 32-TSSOP от -40 до 85
- Synchronizing non-FIFO variations of the THS1206PDF, 219 Кб, Файл опубликован: 28 фев 2005
- Designing with the THS1206 High-Speed Data ConverterPDF, 167 Кб, Файл опубликован: 4 апр 2000
This application report is intended as a guide in the use of the digital and analog portions of the THS1206 A/D converter. On the digital portion, it discusses the main timing features to explain the requirements for initialization and operation. Two interface examples are presented where the THS1206 is connected to digital signal processors TMS320C54x and TMS320C6201. On the analog portion, it of - Resetting Non-FIFO Variations of the 12-bit THS1206PDF, 38 Кб, Файл опубликован: 9 май 2002
The THS1207 and THS1209 are non-FIFO variations of the THS1206. They require some special procedures for properly resetting and configuring the device. This application brief helps explain the necessary steps required to get reliable data from these 12-bit, two and four channel simultaneous sampling data converters. - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS1206 (10)
