Datasheet Texas Instruments TS5A2053DCURE4 — Даташит
СерияTS5A2053
МодельTS5A2053DCURE4
Аналоговый переключатель SPDT 10 Ом 8-VSSOP от -40 до 85
TS5A2053 datasheet
PDF, 924 Кб, Версия: A, Файл опубликован: 18 май 2005
АЦП азиатских производителей
Package TypeDCU
Industry STD TermVSSOP
Width (мм)2
Length (мм)2.3
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
Additional FeaturesLow Harmonic Distortion
Low Power
Approx. Price (US$)0.18 | 1ku
Bandwidth(MHz)330
Bandwidth(Max)(MHz)330
Configuration1:2 SPDT
Crosstalk(dB)Yes
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)5
Input/Ouput Voltage(Max)(V)5.5
Number of Channels(#)1
Operating Temperature Range(C)-40 to 85
Package GroupVSSOP
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
Ron(Max)(Ohms)16
Ron(Typ)(Ohms)7.5
THD(Typ)(%)0.01
Turn off Time (Disable)(ns)4.5
Turn on Time (Enable)(Max)(ns)7.1
VCC(Max)(V)5.5
VCC(Min)(V)1.65
VIH(Min)(V)3.5
2.1
1.15
RoHSНе совместим
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A2053 (5)
  • Semiconductors > Switches and Multiplexers > Signal Switches > Analog Switch
На английском языке: Datasheet Texas Instruments TS5A2053DCURE4
