Datasheet Texas Instruments TPS7A1633DGNR — Даташит
СерияTPS7A16
МодельTPS7A1633DGNR
60V, 5-ВµA Iq, 100-mA, Low-Dropout Voltage Regulator with Enable and Power Good 8-MSOP-PowerPAD -40 to 125
TPS7A16 60-V, 5-µA IQ, 100-mA, Low-Dropout Voltage Regulator With Enable and Power-Good datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 2 окт 2015
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаPPNQ
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
Точность2 %
Fixed Output Options3.3,5 В
Iout(Max)0.1 A
Iq(Typ)0.005 мА
Noise215 uVrms
Output Capacitor TypeCeramic
PSRR @ 100KHz26 дБ
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Regulated Outputs1
Special FeaturesEnable,Power Good
Thermal Resistance ОёJA45 В°C/W
Vdo(Typ)60 мВ
Vin(Max)60 В
Vin(Min)3 В
Vout(Max)18.5 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: TPS7A1601EVM-046
    Evaluation Module for TPS7A1601 Low-Dropout Linear Regulator
  • Evaluation Modules & Boards: DRV8816EVM
    DRV8816 Evaluation Module
  • Evaluation Modules & Boards: DRV8870EVM
    DRV8870 H-Bridge PWM Motor Driver Evaluation Module
  • Evaluation Modules & Boards: DRV8871EVM
    DRV8871 H-Bridge PWM Motor Driver Evaluation Module
  • Evaluation Modules & Boards: DRV8872EVM
    DRV8872 H-Bridge PWM Motor Driver Evaluation Module
На английском языке: Datasheet Texas Instruments TPS7A1633DGNR
