Datasheet Texas Instruments RC4151NB — Даташит
СерияLM331
МодельRC4151NB
Прецизионный преобразователь напряжения в частоту 8-PDIP от 0 до 70
LMx31x Precision Voltage-to-Frequency Converters datasheet
PDF, 943 Кб, Версия: C, Файл опубликован: 29 сен 2015
Pin88
Package TypePP
Industry STD TermPDIPPDIP
JEDEC CodeR-PDIP-TR-PDIP-T
МаркировкаLM331N
Width (мм)6.356.35
Length (мм)9.819.81
Thickness (мм)3.93.9
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Рекомендуемая замена
ReplacementLM331N/NOPB
Replacement CodeS
Approx. Price (US$)1.03 | 1ku
Package GroupPDIP
Vs(Max)(V)40
Vs(Min)(V)4
RoHSНе совместим
  • New Phase-Locked-Loops Have Advangs as Freq to Voltage Cnvrtrs (Rev. B)
    PDF, 1.3 Мб, Версия: B, Файл опубликован: 26 апр 2013
    This application report discusses new phase-locked-loops that have advantages as frequency to voltage converters.
  • 2-Way Multiplexed LCD Drv & Low Cost ADC Using V/F Tech w/COP8 Microcontrollers
    PDF, 564 Кб, Файл опубликован: 14 май 2004
  • AN-265 An Electronic Watt-Watt-Hour Meter (Rev. B)
    PDF, 537 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report provides an electronic watt-watt-hour meter.
  • Versatile Monolithic V/Fs can Compute as Well as Convert with High Accuracy (Rev. B)
    PDF, 535 Кб, Версия: B, Файл опубликован: 29 апр 2013
    The best of the monolithic voltage-to-frequency (V/F) converters have performance that is so good itequals or exceeds that of modular types. Some of these ICs can be designed into quite a variety ofcircuits because they are notably versatile. Along with versatility and high performance come theadvantages that are characteristic of all V/F converters, including good linearity, excellent resol
  • Freq-to-Vltg Converter Uses Sample-and-Hold to Improve Response & Ripple
    PDF, 119 Кб, Файл опубликован: 3 окт 2002
  • AN-311 Theory and Applications of Logarithmic Amplifiers (Rev. B)
    PDF, 517 Кб, Версия: B, Файл опубликован: 23 апр 2013
    A number of instrumentation applications can benefit from the use of logarithmic or exponential signalprocessing techniques. The design and use of logarithmic/exponential circuits are often associated withinvolved temperature compensation requirements and difficult to stabilize feedback loops. For theseconsiderations and others, designers tend to avoid these circuits. Hybrid and modularlog
  • An Acoustic Transformer Powered Super-High Isolation Amplifier
    PDF, 212 Кб, Файл опубликован: 4 окт 2004
  • AN-240 Wide-Range Current-to-Frequency Converters (Rev. B)
    PDF, 302 Кб, Версия: B, Файл опубликован: 29 апр 2013
    This application report discusses a wide-range current-to-frequency converters.
  • AN-C V/F Converter ICs Handle Frequency-to-Voltage Needs (Rev. B)
    PDF, 371 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Simplify your frequency-to-voltage (F/V) converter designs with versatile V/F ICs. Starting with a basicconverter circuit you can modify it to meet almost any application requirement. You can spare yourselfsome hard labor when designing F/V converters by using a voltage-to-frequency (V/F) IC in your designs.These ICs form the basis of a series of accurate yet economical F/V converters sui
Серия: LM331 (3)
  • Semiconductors > Amplifiers > Special Function Amplifiers > Frequency Converters
На английском языке: Datasheet Texas Instruments RC4151NB
