Datasheet Texas Instruments TPS7A1601DRBT — Даташит
СерияTPS7A16
МодельTPS7A1601DRBT
60V, 5-ВµA Iq, 100-mA, Low-Dropout Voltage Regulator with Enable and Power Good 8-SON -40 to 125
TPS7A16 60-V, 5-µA IQ, 100-mA, Low-Dropout Voltage Regulator With Enable and Power-Good datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 2 окт 2015
Package TypeDRB
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаPA5M
Width (мм)3
Length (мм)3
Thickness (мм).88
Max Height (мм)1
Точность2 %
Fixed Output Options3.3,5 В
Iout(Max)0.1 A
Iq(Typ)0.005 мА
Noise215 uVrms
Output Capacitor TypeCeramic
PSRR @ 100KHz26 дБ
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Regulated Outputs1
Special FeaturesEnable,Power Good
Thermal Resistance ОёJA45 В°C/W
Vdo(Typ)60 мВ
Vin(Max)60 В
Vin(Min)3 В
Vout(Max)18.5 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: TPS7A1601EVM-046
    Evaluation Module for TPS7A1601 Low-Dropout Linear Regulator
  • Evaluation Modules & Boards: DRV8816EVM
    DRV8816 Evaluation Module
  • Evaluation Modules & Boards: DRV8870EVM
    DRV8870 H-Bridge PWM Motor Driver Evaluation Module
  • Evaluation Modules & Boards: DRV8871EVM
    DRV8871 H-Bridge PWM Motor Driver Evaluation Module
  • Evaluation Modules & Boards: DRV8872EVM
    DRV8872 H-Bridge PWM Motor Driver Evaluation Module
На английском языке: Datasheet Texas Instruments TPS7A1601DRBT
