Datasheet Texas Instruments TPS61162DYFFR — Даташит
СерияTPS61162
МодельTPS61162DYFFR
Двухканальный драйвер WLED для смартфонов 9-DSBGA от -40 до 85
TPS61162D Dual-Channel WLED Drivers for Smart Phones datasheet
PDF, 2.0 Мб, Версия: A, Файл опубликован: 29 мар 2016
Pin99
Package TypeYFFYFF
Industry STD TermDSBGADSBGA
JEDEC CodeS-XBGA-NS-XBGA-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка61162DTPS
Width (мм)1.41.4
Length (мм)1.41.4
Thickness (мм).425.425
Pitch (мм).4.4
Max Height (мм).625.625
Рекомендуемая замена
ReplacementTPS61162AYFFR
Replacement CodeS
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
Серия: TPS61162 (1)
  • TPS61162DYFFR
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61162DYFFR
